You should be able to import them using Insert Media File to Timeline>Insert DVD/DVD-VR. Then navigating to the Video_TS folder (if you copied that to your harddrive) or on the DVD. Then placing a checkmark beside the Titles and Chapters you want to import.
Generally if that fails, then either the disc is copy protected (MacroVision) or the files are some proprietary format, which Sony is notorious for.
This has not happened before
daddog
File Format: NTSC DVD
Video Type: MPEG-2 Video, Upper Field First
Total Frames: 5,295 Frames
Attributes: 24 bits, 720x480, 16:9
Frame Rate: 29.970
Data Rate: Variable bit rate
Auto Type:
Dobly Digital Audio
Total Samples: 8,480, 480
Attributes: 48000 Hz, 2/0(LR)
Layer: None
Bit Rate: 448
Hope this helps.
Keep in mind this is a problem I have not had in the past. It just started a week or so ago. Up until now all the clips I have used worked just fine in VS9.
Frame Rate: 29.970
Auto Type:
Dobly Digital Audio
Layer: None
Bit Rate: 448
Hope this helps.
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog
They are not in VOB files. That is not the format they are in. Unless I have no idea what I am talking about which is often the case.You should be able to import them using Insert Media File to Timeline>Insert DVD/DVD-VR. Then navigating to the Video_TS folder (if you copied that to your harddrive) or on the DVD
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog
Ok.
I just took a short 30 second clip and pulled the DVD out and put it in my drive. My system would not even recognize it. So I put it back in my DVD camera and finalized it in my camera and then put it back in my system. This time instead of using Picture Package to copy it I just used windows to browse to it and copy it to my HD and sure enough it was a VOB file. A video _ts folder and the VOB files with in it.
Ok so I have learned now to import files that way, but not sure I see the advantage. Up until now I have never had to.
Also I am still left with the issue of all the files from the past year that may or may not work.
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
The method you just discovered is the correct method to import video from a DVD/DVD-VR, unless your camcorder has the capability to transfer using firewire.
To convert MPEG back to VOB is by creating a DVD. The burn module produces the VOB, BUP, etc.. and the Video_TS folders, ie, it creates the structure for the DVD to recognized by DVD players.
