VS10 Not Picking up The Working Folder
KYS
Post by KYS »
I want to create DVD folders on my external harddrive (300gb). When I select the option to send it to the specified location on my external hard drive, it shows me the message:
"The working folder [E:\MenuCreation] may not have enough space. We will help to clean the converted cache file. You can also change the working folder path in Preferences."
I changed the working folder even before the start of the project and after the message was shown, I rechecked and it is also set to the external hard drive.
Working folder is set to my external hard drive which has lot empty space but during the process of DVD folders on hard drive, it is not picking up the specified hard drive and keeps picking E:\MenuCreation as the working folder, this hard drive has less empty space than required.
Please help!
Post by Trevor Andrew »
Hi KYS
Video Studio uses two working folders.
One for the capture and edit.
Select a new folder from File Preferences or the capture window.
The second is dedicated for the burner module.
Share ¡V create disc¡Xlower left icon or press F6
Hope this helps
Trevor
KYS
Post by KYS »
Hi Trevor, yes it did help, thanks.
