Failed to build prewiev graph
ostech
Post by ostech »
Good day all,
I have recently installed vs10+ I am used to working with vs 7 & 9 but never with firewire. The captioned message is what appears on the screen every time I try to capture. The software controls the camcorder ok but when I select capture a message says "unable to switch to capture mode - check if your capture driver is working properly"
Computer: Celeron 3.02, 1GB ram, speed 400, hd 200GB. Fire wire card.
Must admit I have not uninstalled versions 7 & 9, Could this be the problem. I have used the suggested preferences found on the forum.
Some help please.
2Dogs
Post by 2Dogs »
G'day ostech!
Try searching the forum - this is a not uncommon problem.
Check out this thread, for example.
http://phpbb.ulead.com.tw/EN/viewtopic. ... ld+preview
Phil S
motherboard: Gigabyte GA-EX58-UD3R v1.6
processor: QuadCore Intel Core i7 2933 MHz
ram: 6gb
Video Card: NVIDIA GeForce 210
Hard_Drive_Capacity: 1640gb
Post by Phil S »
I had this problem and I think it was due to me installing VS10 BEFORE I uninstalled VS7.
I completely uninstalled VS7 and VS10 using the uninstall procedure for ulead products (found on this forum below) and then done a clean install of VS10. I then had no further problems.
http://phpbb.ulead.com.tw/EN/viewtopic. ... 5773#55773
joosuna
System_Drive: F
processor: intel dual core 3 Ghz
ram: 12Gb
Video Card: nvidia
Hard_Drive_Capacity: 2000
Post by joosuna »
Ostech..You can solve the problem permanently by following the wise advice of our elder sage forum gurus of the video editing world...or for a lazy solution do as I have done..... I just shut off the camcorder and turn it back on..then try capturing again, and the message is gone.
regards
Joe O
Post by Trevor Andrew »
Also check out Ulead's Knowlage Base
http://www.explorecommerce.com/members/ ... 31&ID=7346
Suppose it depends on your DX version
Trevor
