I don't use Movie Factory any more, but I can't seem to delete it off my system. When I try using Control Panel>Add/Remove Programs, something just flashes on the screen too quickly to be read and returns to the list of installed programs. There is no uninstall option, at least that I can find, in the software itself. It's like my computer is possessed. Please help me exorcise this demon.
BTW, the same thing is true of VideoStudio 7, so if you have a clue about that one, please help there also...
TIA...
Can't Uninstall DVD Movie Factory 2
heinz-oz
The answer has been given in your other post. Your uninstaller is corrupted or you have used one of the so called "Registry fixers" which usually "fix it" permanently given enough time. The only solution, well two solutions really, either fix the uninstaller by reinstalling the software first and then remove it or manually remove every trace of the program by following the uninstall routine given in the other thread.
