If there's an Ulead project manager out there - torture him with one month of assembler coding on an oldstyle 8 bit home computer for this product quality, the only food will be water and bread.
I have now discovered that having two files with a filesize more than 4 GB inserted in the time line causes the error 257:0:0 or an hard crash after 90 minutes of processing time, and this hard crash just disappeared when I cutted a 5 gig and a 6 gig file in some 2 gig files. But I did not change the encoding of the source files.
Then I resetted all preference and projeft settings to default. Maybe also some Ini files have been corrupted
(1)
I Created a new project, added my files with the movie wizard, used 'make disk' without ANY special settings and IT WORKS!!!!
The wizard didn't detect my three-file-scene, added some unwanted fadings and clip transition effects and the main screen of the DVD needed a more intelligent title than 'My Project 10' and the default background sound. So further investigations were taken out.
(2)
Next attempt: new project, adding the files by hand.... no games with the DVD menu and chapter settings - IT WORKS!!!!
(3)
Then I enabled the dualpass encoding, and VBR, and I have gotten the error 257:0:0 but no real crash so far. Just a dialogue box.
(4)
Next attempt: using the same project file from (2) , did some personalizing in the DVD chapter menu like adding background pictures and setting the chapter names, disabling the dualpass setting, enabling CBR and I kept the default of 70% in the speed/quality slider, set the bitrate to 5 MBit - IT WORKS. But the quality is not the best.
RESULTS AND FACTS:
(1) now 75% success rate....
(2) 512 MB of physical memory in Windows XP pro is not enough for my movies.
(3) the DVD creation process does not show all of the allocated memory.
(4) the hard crash which causes Windows to send an error report is definitly caused when processing the big files with too few memory.
Unfortunately I cannot double-check it now because I changed from 1x512 MB to 2x1GB mem
a note to ken and Heinz:
I wrote down my system config. And why just don't tell the people that the mpeg encoder in the dvd burner module is different from the mpeg encoder of the main program? CRAZY!
