Can I output a wmv file in 16:9 aspect ratio
jetskirich
Post by jetskirich »
I've been trawling though the posts here, but I can't find the answer to my question.
I'm using VS8 and I want to be able to produce a 16:9 wmv file for the internet (if it's possible). My original files are 16:9 avi files, and I can create a dvd or avi file in 16:9, but when I try to output to wmv, I can only get it to produce in 4:3.
In fact, the original video clips remain the correct ratio, but I've added coloured backgrounds for transitions and an image or two as well and these revert to the 4:3 format, so the two are mixed in the final output.
I've tried all the usual stuff like setting project settings and using custom output settings, but nothing seems to work.
Is there a way to do this to create a file this way?
Richard.
Have you tried rendering your project, to the same format (DV/avi) then using Windows Media Encoder? I don't have any 16:9 video to try this with, I always shoot 4:3.
I did notice with VS8, the only way to set your project settings to 16:9, was to use DV type 2, or NTSC DVD. All the other codecs, prevented the aspect ratio from being changed, however it they did default to Source Frame size.
jetskirich
Luckily I transferred my video using DV type 2 anyway. I just tried your suggestion and it works! Just need to figure out now how to adjust to the frame size I want in Windows media encoder.
Thanks for the help
Richard.
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 11:32 pm, edited 1 time in total.
jetskirich
thanks for the help guys, I finally got it sorted.
Richard.
