DVD Picture Show 2 freezes my PC completely.
I can't neither use Task Manager but I have to reboot WIndows.
I've got Windows XP Pro SP2
The same behaviour of Memories on Tv 2.13.
These are the only programs which freeze my computer.
May yo help?
DVD Picture SHow 2 hangs my PC
htchien
You may have installed some video/audio codec packs like XviD or Nimo in your system. To find out if this is the problem, use Windows Explorer to browse to the install path of DVDPS (usually C:\Program Files\Ulead Systems\Ulead CD&DVD PictureShow 2, unless you have changed it when you install DVDPS), then open the VIO folder under it, then rename the uvAVI.vio and then run DVDPS again. If this works, then the video/audio codec pack is the problem and you will have to remove these codec packs in your system.
After you make this to be solved, you can rename the uvAVI.vio back.
Hope this helps.
H.T.
Hope this helps.
H.T.
