creating dvd or DVD folder
cschloman
Post by cschloman »
program runs fine until the share section in creating a disc. it also will not allow me to create a dvd folder
suggestions of burning at different speeds and using good quality brands of disc, I have already tried.
had computer checked over by technicians , they feel the problem is to do with the program itself as it says it is an application error.
have downloaded patches regarding dvd burning.
it did produce 1 disc that was fine to play on my DVD player.
heinz-oz
Post by heinz-oz »
How is it the program if it worked once? What did you do since?
This might give you an idea about the detail we need before anyone can hazard a guess http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Please click here --> Image so that we can then view your system specifications.
Next Please click here:
VideoStudio RECOMMENDED PROCEDURE by JC Hunter
DVDDoug
Moderator
Post by DVDDoug »
You may have a corrupt video file. A bad video file can cause all sorts of strange problems. (A bad video file will often play OK, but cause trouble when you try to make a DVD.)
If you are using a DivX or Xvid file, that file is probably the source of your problem. MPEG files sometimes cause trouble. DV files (from a DV camcorder) rarely cause trouble.
But like heinz-oz said, we can make a better guess if you tell us a little more about what you are doing.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
It would also be useful to know if you have the Nero suite or the Roxio Easy Media Creator suite on your computer. Nero's InCD in particular has a tendency to take over your burner, denying access to it for other programs. It has to be totally removed to regain control over your burner. The Roxio drag-to-disc facility does the same thing, though I understand it can be internally disabled so that you don't have to totally remove the module.
