Transition removal
roger trigg
Transition removal
Post by roger trigg »
I captured with a default transition turned on. Is there a way to remove the transitions en masse? There's a sequence of 500 clips so don't fancy doing it manually.
Post by BrianCee »
No - don't know any way to delete all transitions in one go - if I was in your position I think I'd find it easier to dump that capture complete - turn off the auto transition and capture again.
randazzo
Post by randazzo »
Easy enough.
Move al the clips from the time-line to a library (temp for instance). Delete al the clips from the time line. Then disable the automatic transition feature and move al your clips from the library to the time line.
Jean-Pierre
Jean-Pierre Randazzo
