MF4 Printing Labels
rjgeisler
MF4 Printing Labels
Post by rjgeisler »
I have an Epson R300 printer which allows me to print a label directly on the CD/DVD but the predefined 12cm mask is too big which allows the image to print off the edges of the disk.
Is there some way to adjust the size of this mask?
I also tried to use "Custom Defined" but it uses the same mask and still no way to adjust the size.
Does MF-5 handle this any different?
ruggy1
Post by ruggy1 »
Do not use MF to do the printing - use the software that came with the Epson - it is superb. You simply import an image from any of the MF background directories, drag it to cover the disk outline, add any text you like and away you go. If you use a background menu image during authoring it is a nice touch to select the same image to print on the DVD.
MF2, MF3, MF4, MF5, VS7, VS10+, VS12, Nero Vision Express. Ricoh and Sony 16x DVD recorder, Sony HC5 High def camera. Also Canopus ADVC110 for AV/DV input through firewire
