VS is not Working
cmdralpha
Ige many error codes trying to do this
Post by cmdralpha »
1) unable to loadthe library 'tBYB'
2) error number 0x80040702 description:;; failed to load DLL: xSystem
videostudio 10 plus has NOT worked in 3 weeks and I have demanded support ever since. I get the run around.
need real time support chat to fix your failing software.
URGENTLY Requesting Immediate HEEEEELP and Support.
Denis La Bine, president Gnn Broadcasting.[/img]
Welcome back Denis, It's been over a year...:)
Post was split from the Announcement thread
Has VS10 worked previously then stopped working? That would indicate that something may have changed on your system, that affected VS. If not, then you have a faulty install. I know you had to received one of Ulead's standard recommendations, uninstall, and reinstall, but did you do a complete, clean uninstall? Try doing a complete un-install/re-install. Ulead programs leave a lot of files behind. So just doing a simple add/remove programs from the control panel and then re-installing may not correct some issues. Instructions can be found here : Re-installation of Ulead Products
When installing make sure you have Admin rights to the profile(s), all background applications/utilities are disabled.
Please complete your System Information located in your profile. Clicking on this button -->Image
will take you to the instructions if needed.
