Another try - --
Millygirl
Another try - --
I don't know but I can't seem to retrieve my postings here!
GOOD THING I HAD COPIED THIS BEFORE EXCITING THE LAST ONE!
Computer
HP Pavilion z320n
120GB
512 RAM -yes, I am upgrading this!
Video Camera
Handycam Vision Video 8 CCD - TRV12 - NTSC
Video Capture Card
Lifeview FlyTV Prime Series 30
In using the software, Ulead VideoStudio Plus 10, I had tried a number of formats including AVI, MPEG, MPG4, and WMV. I still could not hear any sound.
I have my cables setup so that the yellow cable is colour matched from the video camera to the back of my capture card. The black cable is connected to my video camera to the Audio In in the capture card. NOTE: I have also tried having the black cable in the Line In slot in my sound card - still did not hear sound.
I have also adjusted my sound device for selected of either Line In or Video depending on which one I had it plugged into at the time. I have also made sure they were all at top volume.
Is there anything I have missed?
Melissa
Computer
HP Pavilion z320n
120GB
Video Camera
Video Capture Card
Melissa
heinz-oz
Hi Milly,
you are using an 8mm analog camcorder and are trying to connect through you TV tuner card, right?
Are you using this cable?
You mention a black cable which you connected to your cam, which one is that? I think you are having your connections all wrong. The read and white connector carry the audio signal. If your cam is mono, not stereo, one of the connectors will be missing. If your card is mono, your cable will be missing one plug.
Please advise the details of your connections.
heinz-oz
Heinz -- I don't think you have the correct device. I get quite a different set of individual cables when I go to http://www.lifeview.com.tw/html/product ... rime30.htm
Nevertheless, I still think Milly may have one of the cables in the wrong slot. The Camera audio is supposed to be connected via the cable with the red and white RCA connectors to a black stereo plug which goes into the BLUE audio-in connection on the back of the computer. The only fully black cable I can see is the audio-out cable with identical stereo plugs at each end and is connected to the green audio-out socket on the computer.
Milly, can you tell us specifically which cables you are talking about, please?
Millygirl
Hello Heinz!
No I am not using that cable. My cable has on both ends the black and yellow ends as shown in the picture. So in other words in doesn't have the red and white cable nor are they attached to the rounded cable as shown.
Am I using the wrong cable? If so, where am I able to get one of those? I live in Canada.
I see on my capture card I have a spot for S-Video, Audio In, Audio Out, AV, Remote, TV and FM.
On my video camera I have Audio Out and Video Out.
Melissa
Melissa
heinz-oz
heinz-oz
Millygirl
Hi -
For one thing my video capture doesn't look like the one shown. I only have a yellow coded plug and not a blue one. But nevertheless I do have the Yellow cable going from my Video Out to the AV In on the capture card and then I have the black cable (which is the 2 standard cables in Canada to use) from the Audio Out to the Audio In on the capture card - as shown except it's a different colour cable.
Melissa
Melissa
Millygirl
I have to say that I am even more confused now because my capture card does not look like the one on their site but if I look under my device manager it says "Lifeview FlyTV Prime Series 30". I just got the box out and says nothing about Lifeview on it but there is a photo of the card on it which says TV Capture.
Melissa
Melissa
heinz-oz
Millygirl
heinz-oz
Millygirl
- ram: 2 GB
- sound_card: Intel GMA 950
It is possible that you now have the cables connected correctly and the fault is elsewhere.
Check that you have the Windows Volume Control for RECORDING correctly set up. You have to choose the correct input device
There are several including:
Stereo Mix
Mono Mix
Aux
Video
CD Audio
Line In
and a few others, only 1 at a time can be selected.
here's how to do it in pictures
Stereo Mix
Mono Mix
Aux
Video
CD Audio
Line In
