MPEG plays back too fast
nigelc
Post by nigelc »
I'm new to VS - using version 7.
Trying to convert a VHS to DVD. Preview is fine but when I try to capture into MPEG format it plays back too fast. Testing with a 14 second clip plays back as a 4 second clip.
Using Hauppauge WinTV USB adaptor.
robertpcx
Post by robertpcx »
In the edit mode you can adjust the speed of the video.
nigelc
Post by nigelc »
Thank you for your reply.
Although your solution does slow the playback down to the correct speed, due to the massive decrease required (needs to playback at 35% of the recorded speed), there is also a massive degradation in sound and picture quality. The sound also moves out of sync very quickly (within 2 minutes).
This would be unacceptable for the 2 hour video I want to transfer to DVD.
From all the problems I've read here regarding VS, I've decided that it is worthless for me. I get along great with DMF3 copying my camcorder tapes direct to DVD and creating slideshows.
I'm going out to buy a Dazzle DVC90 which has the hardware and software together. Sounds like a better option than using software that might work with my own hardware (if at all).
Thanks again but I'm giving up on VS.
