Stills, slideshow and transitions
moviemunk
Post by moviemunk »
I have had DVD Workshop for a while but have never done a slide show. I tried importing still JPEGs into the program which seemed to work fine. However I cannot create a slideshow which lasts more than on slide and I cannot apply any transitions. In fact, the transition dialog is grayed out. What is up with this? I called tech support and they had no answer.
GeorgeW
Re: Stills, slideshow and transitions
Post by GeorgeW »
moviemunk wrote:I have had DVD Workshop for a while but have never done a slide show. I tried importing still JPEGs into the program which seemed to work fine. However I cannot create a slideshow which lasts more than on slide and I cannot apply any transitions. In fact, the transition dialog is grayed out. What is up with this? I called tech support and they had no answer.
What version of DVD WS are you running? (1.x, 2.x, Full, SE, Express, etc...)?
In DVD WS 2.x, you cannot add a transition because you only have one picture in the slide show (nothing to transition to). Drag more stills to the filmstrip on the right side of the screen :)
George
moviemunk
Full version with the current patch
Post by moviemunk »
I lined up several pics in a row. Still can't seem to create show or add transition.
GeorgeW
Post by GeorgeW »
Where did you line up the pics? Along the bottom, or along the right-hand side :?: (they should be vertically along the right-hand side of the screen -- assuming DVD WS 2.x)
Or, shift-click to select a range of pictures, and drag them to your timeline along the bottom. (or CTL+Click to select specific pictures, and drag them to the timeline on the bottom).
George
moviemunk
Post by moviemunk »
Ver 2.3
Thanks for the advice on the layout. I was lining them up one by one along bottom like video clips. The instruction is vague but I may have missed it. Anyway, everything working fine. You would think tech support would have mentioned this. Thanks again.
DiscCoasterPro
Post by DiscCoasterPro »
Sadly it seems that tech support these days for most anything we purchase amounts to the first warm body that applies for the job. :( Most of the time they have much less a clue than we do.
