video capture problem
ann hackett
I am following the tutorials posted elsewhere on this site (SJJ1805 and jc hunter_2), which are great. I managed no problem to capture 3 clips as described into one video library project. When I try to do the same again I get to the stage where I switch the camcorder on but I never get the message "anew device is plugged into your computer. Do you want to use it?" This happened no bother first time round - now it's as if the camcorder isn't even there. What's happened? Thanks for any help ....
ann hackett
Yes - I've done these things in various orders nad lots of times. I've just been studying the firewire cable. In the camcorder end of the cable coming from the pc I can see four gold pins, but in the camcorder socket I can see only three. Perhaps it was always like this - I'd never looked before - but now I'm wondering if a pin has broken? The camera doesn't seem to be detected in My Computer either..
That sounds like that could definitely be a problem. Firewire cables are relatively cheap and can be found at a computer or office supply store (Staples, etc.)
Also, some cameras will not be detected when powered by the battery, but only when "plugged in".
Jeff
Dentler's Dog Training, LLC
The small camcorder-end firewire plug most definitely should have four pins showing -- I have just cross-checked with my own 4-pin cable and can clearly see all 4 pins. So yes, it does sound as though your cable is defective. So you should get a new one. You might also want to check to make sure the broken pin is not stuck in the in-jack in your camera!!! That could require a visit to your camera shop if there is insufficient outside the plug to allow you to get a grip with tweezers...
