Transition audio
suethomo
Transition audio
Post by suethomo »
I'm a new user to Videostudio8. When I apply a transititon it cuts out the first bit of sound of the audio track of the new clip(the sound that was on the video) . Is there anyway of overcoming this as there is important information on this track. ie I need the sound on the start of the 2nd clip not the sound at the end of the first clip
Any help appreciated.
Calver
Post by Calver »
I have the same problem with the mpeg after using 'Share/Create Video File'. I can only overcome it by turning off 'Perform SmartRender'.
John
Post by Trevor Andrew »
Hi Sue
Do you mean that the sound on the second clip does not play until after the transition has finished?
If this the case----- have you installed the VideoStudio 8 Update Pack (Build Number: 8.01Try this link
http://www.ulead.com/tech/vs/vs_ftp.htm
Trevor
suethomo
Post by suethomo »
Yes this is what I mean. However when I install the update packs I get the message "Cannot find videostudio 8, Video Toolbox 2" How does one get this. I installed Videostudio 8 from a CD & as far as I am aware have installed everything on the CD.
Sue
suethomo wrote:Yes this is what I mean. However when I install the update packs I get the message "Cannot find videostudio 8, Video Toolbox 2" How does one get this. I installed Videostudio 8 from a CD & as far as I am aware have installed everything on the CD.
Sue
Sue
You do not need the toolbox update patch.
You need either:-
VideoStudio 8 SE Update Pack
(Build Number: 8.01, Release Date: 2004/10/22)
or
I think this is the one for the CD version
VideoStudio 8 Update Pack (Build Number: 8.01, Release Date: 2004/09/06)
go to
the download file is called uvs8_patch1_e.exe
and is 18.4 Mb
Hope this helps
suethomo
Post by suethomo »
Many thanks - the update patch did the trick.
Sue
