Multi Track Transitions (like fades)
jmcumber
Can someone explain how to apply a transition from an overlay track (say track Video 2) to the next clip in the timeline. The Video 1 track has an overlap of clips and those tracks transition, but the Video 2 track needs to have the transition also.
jmcumber
I have Media Studio Pro 8.0.
I hope what I am asking for is clear. I have two clips. One is the primary clip (clip1) on Video 1. The second is an overlay clip (clip2) on Video 2.
I then took another clip (clip3) and inserted in Video 1 with an overlap so I could add the transition.
What I am trying to do is get clip2 (the overlay clip) to transition to clip3 like clip1 does.
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Inter track Transitions
If it's just a simple fade, you can apply a transparency overlay filter and adjust an intermediate keyframe to the starting/ending point of the fade.
There are many ways to do it, but surely the simplest way is to use a virtual clip, as this is the sort of thing they were designed for?
If he adjusts the transparency of the overlaid clip, then decides he wants it to fade over (say) two seconds rather than one, he's got to make two changes - the change to the overlap and the change to the keyframe where the overlay transparency starts. If he uses a virtual clip, he just makes the one change to the overlap.
- ram: 2 GB
I have re-read this several times and to be honest am not quite sure what you are doing with clip 3.jmcumber wrote:I have Media Studio Pro 8.0.
If you have clip A on Video 1 and then Place Clip B on video 1 but overlap those two clips you get a transition.
If you place clip C on video 2 and Clip D on video 2 and overlap the clips you get a transition.
You don't get a transition between The videos on track 1 and the videos on track 2 They will 'cut' in or you can apply things like moving paths or the Terry Stetler method to achieve a transition between the tracks.
I have thought of a simple way to create the appearance of a transition between the two video tracks - all it involves is a simple cut.
Let us suppose you have clip A on video 1 and Clip B on video 2.
To make a transition of 1 second simply make a cut 1 second from the end of Clip B and also from the same location on Clip A. Now drag Clip B straight down onto video 1. What happens is the one second you dragged down forms a transition (on track 1) and then due to the cut the clip on video 2 takes precedence and 'hides' video 1.
Due to the straight cut the effect is seamless.
I can't see why it's not making any sense to you, Steve.
He's got a clip on V1 at 0:00:00;00 lasting 5 seconds. He's got a clip on V2 at 0:00:00;00 lasting 5 seconds, with its overlay options enabled. He's overlapping a clip on V1 at 0:00:04;00 so you get a one-second crossfade (or whatever) between the two clips. He wants the crossfade to apply to the overlay, too.
OK so I've made up the start times and durations, but you get the picture?
If it's a crossfade, Devil's method works, but requires two operations if ever the crossfade duration is changed. One to change the overlap and one to move the overlay keyframe. My method (virtual clip) works just by changing the overlap, and also allows the overlap transition to be something other than crossfade.
I'd agree that the Virtual Clip would work very well here. The clips on V1 and V2 can be combined into one "Virtual Clip", and then it can transition to the 3rd clip in the main timelineGorf wrote:I can't see why it's not making any sense to you, Steve.
George
