How to split audio file and save the clipped audio file?
Is it necessary to keep the original source audio file saved?
splitting audio file
NBHATT22
SAVE AS ".mp3" file??
Joe O:
Thanks.
You mentioned about saving the clipped audio clip as a sound file. I can only see SAVE AS ".VSP" file option, not SAVE AS ".mp3" file.
Thanks.
And it does not save as .mp3. You have the choice of .WAV (which I would recommend), .wmv or .mpa.
Also be aware of a little sleight of hand that VS indulges in when you split the audio. In effect, it copies the main audio track of your video and places it in the voice track. But in actuality it also retains the original audio, but mutes it. If you look at the mute button when you highlight the original video, you will see that it active. So even though you split off your audio and even make a new file out of it, you can always still revert to the original audio in case you later change your mind or make a mistake!
