sXeChic wrote:Believe me, I answered all questions.
My question was a bit of a trick question - in that it was a repeat of a question posed previously, and which, in my reading of the thread, you never answered.
Anyway, now we know more or less what your connections are.
sXeChic wrote:I am using a composite connection from my DVDR to my capture card.
The video cable is actually one of the 5 color Monster cables using the green video connector. So out of all 5, only the green video part is plugged into my DVDR and Capture card.
There's no reason to suspect any problem with the cable, but it would be so easy to check with another cable that it might be worth trying, just to rule it out.
sXeChic wrote:Between my cable box and my PC is a cable (coax?), so I have cable coming out from the wall, into a splitter, another cable going into the box and the other into my capture card, so I can record one channel while watching another.
So you are using the coax output from your cable box into the pc, but you have another coax connecting to the capture card from the splitter.
Anyhow, what is your video source? When you get the block problem, are you capturing "live" from the splitter box or from stuff on the DVDr?
Just to rule out problems with the splitter box, try disconnecting it and see if the problem persists with a coax from the wall directly to the cable box or your capture card, depending on your answer to the above.
