Can someone help?
I am trying to add a small animated gif to an image.
I load the main image first and than add the animated one. my probblem is it shows up up in the upper left hand corner. Than when I drag it to where I need it the animating starts in the left corner and than the object moves to the correct spot. I hope that make sense. I am just trying to be able to positing it to the spot I need it on the image.
I am using gif animator.
Also when doing a text banner canI have different name appear one after another?
Lisa
Help with image..
LisaNJ25
Help with image..
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
As soon as you add the animated gif, select the Pick tool
. Make sure the Attribute toolbar has "Move active object(s) only" checked.
Drag the added animation to where you want it.
Use the "Synchronize Objects" button.
Use these settings:
Select source image: leave this at the frame showing.
Objects to sychronize: Active objects only
Apply the following attributes: select only X offset and Y offset.
Apply to: All frames.
That's it!
As for the banner text, you would have to add another banner text object. You can't have one banner text object change it's text.
Use these settings:Select source image: leave this at the frame showing.
That's it!
LisaNJ25
- VikingAnimations
- ram: 4 GB
