I don't actually have the Realtek Vista drivers installed - just the XP drivers from the ECS website (I have an ECS KN1-Lite). It works fine in Vista - except, of course, the issue with UVS 8.
Also, if I have to run a program as an administrator, it is *not* a Vista issue - it's a program that was written in a broken way that XP allowed to work because everything runs as administrator by default in XP (if the user is an admin, that is). That's bad, and it's bad that a program needs Administrator privileges to run correctly. IMHO, MS fixed this in Vista, and now the programs that were written incorrectly need to be fixed.
I did manage to get the trial version running as admin, but the issues are even worse. First of all, the sound still does not play at all, but I don't get an error message this time, it just doesn't work. It will also not show the running video in the preview window - it just goes black. I can pause on any frame, and advance by frame, and I can see the images, but not during play. Very strange.
Anyway, it seems an upgrade would be pointless at this point - I will just have to continue using version 8 on XP. Thanks for your suggestions.
... HH
curunir wrote:
htchien wrote:Whenever I try to play a project file, I now get the error:
"Failed to use DirectShow video engine. Cannot play back the audio stream: no audio hardware is available, or the hardware is not responding."
[13102:2:4]
Of course the hardware is working fine (it's built-in sound on an ECS KN1-Lite, Realtec AC '97 audio). There are no errors in any log files I can find, no other programs have problems with the sound.
Am I just SOL? Or is there a way to fix this?
curunir wrote:Hi, Realtek has changed something in the driver for Vista to cause the incompatibility. It should be resolved in the upcoming UVS 10 Vista.
htchien wrote:Upon install of UVS 10 Trial version, windows tells me "This program has known compatibility issues". I can't find any details regarding what the issues are or why this message is displayed. The only details are "for more information, Contact Ulead Systems, Inc." (!!)
If I click past all these errors (happens a couple of times), and get to the end of the install, the program will not run at all. I only get "Limit users can not try this product. You can use normally after successful activation."
So it doesn't seem to run at all. Even if I wanted to activate it, I can't get past this message to get to the activation (wherever it may be).
Is this just a Vista issue, or does the "trial" version not do anything?
It's a Vista issue.
UVS now is going through the Vista compatibility process and will release a Vista compatible version after Vista is been released.
For Limited User issue, please go to Control Panel->User Account in Vista, and then uncheck the User Account Control check box. Or, you can right click on the program icon and select Run as Administrator.
If not uncheck the UAC box, Vista will run every program in limited user account type by default.
H.T.
