I'm using VS9 and want to merge some music tracks.
If I put both tracks on the audio timeline, fade out the first, fade in the second, is there a way of having both fades working simultaneously?
At the moment the only way I have found of doing it is to put one track on the audio timeline and the other on the voice recording timeline and overlapping them.
Also, can I control how long the fade in and fade out takes for a given piece of music?
Merging music/music overlay
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Re: Merging music/music overlay
That is the only way to accomplish this to my knowledge.pagallery wrote:I'm using VS and want to merge some music tracks.
I can't rember if the "audio view" is part of VS9 or not but if it is, select your audio then click the audio view button. A red line should appear in the audio. Use this line to control the audio levels.Also, can I control how long the fade in and fade out takes for a given piece of music?
I recommend Audacity to do any audio editing beyond VS capabilities.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Adjusting Audio Fade In/Out time
In the audio mixing panel via audio view - play the project whilst adjusting the volume fader- or in audio view select the track in the time line then click a point on the rubber band to add a key frame then drag the line up or down to adjust the volume at that point, repeat as needed.The default duration for all clips is set in the edit tab of Preferences
Hope this helps. regards Ken
