put logo on 1000 images
markfok
Post by markfok »
hi,
i've a customer requesting to insert his logo (small image) on 1000 images files. what is the procedure to insert the logo on these image using batch/task manager without open one by one and save it again. thnks
mark
PhotoImpact Help file wrote:To record a quick command:
1. In the Task Tab, click Create a new task.
2. Enter a name for the sequence of actions that you want to record, then click Record.
3. Begin applying a series of commands to your image. For instance, you can firstly create several objects. Then, click to select an object and choose Properties from the right-click menu. Here, you can change the Merge method, Transparency, and so on. You can also apply menu commands or toolbar actions. All of these will be automatically recorded in the QCP.
4. After you have applied the desired commands, click Stop. To add more commands to the task, click Record again and continue working on image.
Note: You can also rearrange the task commands here by simply dragging a task command to a different location on the Task list. You can also right-click the list to open a pop-up menu to customize the Task list.
After recording a series of actions, you can apply them all or just a select few to another image.
To apply an entire series of actions to an image, simply click Play in the Task Tab. All recorded actions will be applied.
To apply a single command to an image, use the Task Tab and click the desired command.
Notes:
¡P Click Task menu commands and select Task Manager on the pop-up menu to organize and edit tasks in a set.
¡P Click Batch Task to apply a command to all image files in a selected folder.
¡P Click Add to EasyPalette to save a task in the EasyPalette for later use. You can choose the current image or a default task icon as the EasyPalette thumbnail.
