Windows XP 64 bit Video file display.
david1951
Hi I wonder if anyone else has experienced this problem. When importing an avi or mpeg2 file into Video Studio 9. The image is correct but when played on the time line only the upper quarter is dispayed (fills whole pane). If I amend the properties or add a video filter it then pays Ok. Restart VS 9 and same thing happens again. Similar problems with MS Movie maker also. Seems to be the XP 64 box causing the problem as if installed on XP Home 32 bit is Ok. Your thoughts are welcome on this one.
htchien
WinXP X64 is not in VS 9 OS support list. If you wish to use VS in WinXP X64, you might need to upgrade to VS 10 because VS 10 is been tested in WinXP X64.
http://www.ulead.com/vs/sysreq.htm
H.T.
H.T.
Ted (H.T.)
