I think a lot of users get confused at this stage so just to clarify.Phil S wrote:............Why do these procedures differ from the Recommended procedure given at the top of this forum?
These procedures tell you to render and produce a DV.AVI file after editing, but the recommended procedure tells you to render to a MPEG2 file.
Every time you render (create) a video file you risk losing some quality and you risk other issues such as out of synch audio/video. You therefore should aim to render a file the least number of times possible.
It is a generally accepted fact that if you can capture (or in the case of most camcorder recordings - transfer) your video footage in a non lossy format such as DV (avi) then you should do so. Not everyone can enjoy that luxury because with such a wide range of video recording equipment and a wide variety of video sources - TV cards - Digital cameras - camcorders - internet - mobile phones - CCTV systems - Sky+ boxes - DVD discs and so on. Furthermore different hardware systems have different connection capabilities - USB, Firewire, SCART, RCA and so on, that what may apply to some users cannot physically be done by others.
Think of the whole process as a 3 step procedure.
Step 1. Get it onto your hard drive.
As described above not all users can do this the same way.
Establish what is best for YOUR setup and the best possible settings for YOUR equipment and source materials.
It is a widely accepted fact that DV (avi) is an easier format to edit than MPEG2 but that does not mean it is impossible to edit MPEG2 and as mentioned above, for some users it is unavoidable.
Step 2. Edit.
What this means is that you place your source materials from step 1 onto the timeline or overlay tracks. make your cuts, add your transitions, titles and extra backgrounds sounds - generally you tidy it all up, cut out the rubbish and put in all your Steven Spielberg Special Effects.
At this time, your original source materials remain untouched on your hard drive. You have simply created a very large text file which is a record of your intended cuts, transitions titles and so on. You save this large text file as a VideoStudio Project File - or in the case of MediaStudio - a MediaStudio project file.
Now what you do is to apply all those cuts, transitions, titles and so on and create a new video file. There are two ways to do this.
Method 1 which is my preferred method, is to create a brand new video file on your hard drive with all of those edits processed. It is no longer a project file it is now a standalone and playable video.
When you do this - you don't want to render it again - we are aiming to render ONCE to avoid loss of quality and any other side issues such as audio/video synchronisation. Our target device will be a DVD disc playable in a standalone DVD player and so we need to render to MPEG2.
If however you are producing a video to place on the internet you would no doubt create one of the following
DivX / Xvid / MPEG4 / WMV / Quicktime or some other format associated with videos you find on the internet.
The reason why this is my preferred method to Method 2 below is that you can now play this video on your computer before moving on to step 3 - authoring. You now have the opportunity to watch the video on your computer with those edits having been implemented. If you decide further editing is required you simply go back to your project file and edit it further.
Using this 'Method 1' you must work out in advance the appropriate bit rate and quality settings so that the completed project will fit onto your DVD - otherwise you will end up rendering the video a second time to reduce it to fit.
Method 2 - place the project file into the authoring module.
Here you have not rendered your video file but instead you render the file as a part of the authoring stage. Technically there is no reason why you cannot do this. Practically though you must consider what effect it will have on the entire project if you then create your completed DVD and then realise you needed to do further editing. Will this affect the placement of your DVD chapters and so on. You might end up having to redo the authoring stage again.
Either way your video will get rendered to the required format - normally MPEG2 as most users will be creating a DVD disc playable in a standalone DVD player. This will take the same amount of time no matter which method you choose. In other words if you create the video file first using method 1, your video has already been rendered and so will not be rendered again and so the authoring stage will appear to take dramatically less time than method 2 where the file must now be rendered.
Step 3. Authoring.
This is the stage where you now create your DVD menus and navigation structure, chapters, Menu background sounds and images and so on.
From this you burn your completed project onto your DVD disc ready to play in your standalone DVD player.
I hope this clarifies the procedure and from this you can see that you should NOT create an avi file from Step 2 but instead either create a DVD compliant MPEG2 file or place the project into the authoring module at step 3.
