WinFast PVR Capture Setting
paulwho
Post by paulwho »
I have a problem when I capture a Analogue TV show using the LeadTek WinFast DV2000 PVR softwear. What happens is after I've captured either to HDD or direct DVD burn the video lip sink is OK but the longer the clip goes the more out of wack is the lip sink.
The Capture Formate Profile
DirectBurn DVD :
Video Codec : MPEG-2
Capture Size : 720 x 576
Bitrate : 4888 kbps
Capture Quality : Good Compression
Frame Rate : 25,000 fps
Audio Codec : MPEG-1
Audio Layer-11
Bitrate : 224 kbps.
Paul
Corel Video Studio Pro X2, Windows 7 64bit, Asus P5Q Motherboard, Asus Nvidia 1GB GeForce 9600GT, Intel CPU 775pin 9400, G.SKILL DDR2 1600 8GB 8500, 2 x SEAGATE SATA 3.5 HDD 500GB 16MB Cache
I used to have that exact same card. Others have reported lip sync problems when capturing using Video Studio. I didn't have that problem, but did experience other issues. I then started using the Winfast program which comes with the card to capture direct to DVD format mpeg-2 (though with a better/higher quality bitrate) and then would import that into VS for editing. I never looked back. It is often better to use the software which comes with a piece of hardware, and in this case, I also found that the Winfast software gave a few more quality options controls than VS for the capture settings.
paulwho
Post by paulwho »
Thanks for your reply >
So what settings are you using when capturing a TV show with WinFast PRV ?
I must have something set wrong..
Paul
htchien
operating_system: Mac
Post by htchien »
Remember to update your WinFast PVR driver and the Wizard software from Leadtek, it should fix some problems on capturing.
Hope this helps.
H.T.
Ted (H.T.)
