How to Burn 16:9 (Widescreen) Video?
pepsi_cola40
Post by pepsi_cola40 »
I have a 16:9 (Widescreen) AVI file. I burned a DVD with it, like I do for 4:3 (Letterbox) videos. But: when I play the DVD on my TV -- a normal TV, not widescreen -- the picture looks "stretched". i.e. instead of a black margin on top and bottom, the video is resized to a 4:3 ratio and looks really ugly.
Is there an option in DVD Workshop 2 to change to 16:9 format? I noticed that the Preview window has a 16:9 button, but this does not affect the way the video is burned.
Thanks!
htchien
operating_system: Mac
Post by htchien »
When you right click on the clip and select Output Display Options, what do you see??
What's the CODEC used in the wide-screen AVI file??
H.T.
Ted (H.T.)
pepsi_cola40
htchien wrote:When you right click on the clip and select Output Display Options, what do you see??
Under "Display aspect ratio" it says "4:3" and it's disabled (grayed). Under "On standard TV" it says "Letterbox only" and it's disabled too. "On widescreen TV" is enabled but is useless to me.
htchien wrote:What's the CODEC used in the wide-screen AVI file??
XviD. The movie's precise frame size is 576 x 240 pixels.
pepsi_cola40
pepsi_cola40 wrote:The movie's precise frame size is 576 x 240 pixels.
Actually, when I looked at the frame size, I realized it's not a 16:9 ratio, but rather 12:5. That explains why DVD Workshop couldn't handle it. In case someone's interested, here's how I solved my problem. (It took me quite some time to figure out, so I hope it helps someone. :D) This solution converts all non-standard ratios to 4:3:
1/ Open the file in VirtualDub (I personally use VirtualDubMod).
2/ Go to Video > Filters...
3/ Add a "resize" filter.
4/ Under "New width" and "New height" put the original width and height (because we're not really resizing). So, in my case, it's 576 by 240.
5/ Check "Expand frame and letterbox image".
6/ Under "Frame width" put the original width. So, in my case, 576.
7/ Under "Frame height" put your original width multiplied by 0.75 (in order to obtain the standard 4:3 ratio). So, in my case, 576 x 0.75 = 432.
8/ Save the new file.
