Just a quickie, why is it that when I create disc then insert a video file in this case a mpeg that is 400mb, the bar at the bottom jumps up to 2.2gb?
I have followed the recommended procedure, made sure the compression settings are the same. I know Im missing something but cant figure it out. If this helps -
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 192 kbps
The only thing I need changing is to PAL but would that change the file size?
Please help
newbie - need help with Recommended Procedure
maddrummer3301
I am confused, doesn't take much i know.
Where did you get the video file from?
Did you create it from Share create video file?
What version of VS are you using?
MPEG files
Upper Field First
(DVD-NTSC), 4:3
How long is the video file, frames or seconds.?
Trevor
MPEG files
Upper Field First
(DVD-NTSC), 4:3
Trevor
