jparnold wrote:How many other expensive software applications cause so much frustration as VS10? When we spend money on anything we expect that it will do the job it is advertised to do and that we will get value for money.
I too have never experienced any problems using VS8 or VS9.
I use Canopus hardware and Adobe Premeire, so after spending £1,000+ I still had initial problems getting it to work and sometimes have to sue a work around.
Does that answer your question?
How many different computers do you think there are in the world?
Take one make and model.
Pick a dell one, most people know them.
Do you think every one of these is exactly the same?
No, Why? Because people have different software installed. May install updates to these, maybe not, windows updates or not. Then even if each one has exactly the same software, it will depend on which order it was installed in, which order updates were added, this can make a terrible difference. Lso things like whether you live in a PAL or NTSC country, which language version of software etc you use.
There you go, all of a sudden just about every single pc in the world is going to be different.
You want to spend £35 on software, but expect many millions of man housrs trying to test it on every conceivable combination of pc.... I don't think so.
If you want this sort of stuff, buy a Mac. You can only use certain hardware, certain software so you stand a much better chance of it working, but even so, check out forums and you'll find people still have problems.
I totally agree buying software and expecting it to work is what we all want as customers, but to think that the companies don't try to deliver this is just plain stupid.
This bit....
now let's see WHAT DID I LEAVE OUT? humm it is allways burnin on all other programs EXCEPT Ver 10+
From gnn....
What did you leave out? Well the problem you are having for a start. Apart from listing a load of things, you haven't said what your actual problem is, so nobody here will be able to help you out, and if that was the sort of mail you sent to Ulead, it's no suprise you haven't received anything useful back.
You need to help yourself before others are willing to help back
