Importing TGA file sequence into layer track of VS10+
dthemusicman
Post by dthemusicman »
I've been attempting to import or load a TGA file sequence into a layer track in VS10+ from C3D without any luck. Does anyone know if this is possible. I've made a number of attempts in different ways but still it won't accept the file......any thoughts. Thanks
Since this is a sequence, are you using Insert Image or Insert Video? I think for sequences you need to use the Insert video. It's the same if you are wanting to insert an animated GIF. Using Insert image will only get you the first frame, insert video gets the entire animation.
dthemusicman
Thanks Vidoman, I tried that very thing without luck the first time....after trying again because of your reply and by giving it a little more time I see that works fine. It appears as tho the layer track takes more to render and was being lost due to my lack of patience. Thanks again
