i just got a DVD-HDD recorder and recorded a couple of test videoclips i want to import into VS8 for editing.
So i used the import DVD/DVD-VR function where i can select the clips and import them wich seems to work fine.
But the videoclips doesn¡¬t have audio once imported.
In the Import screen VideoStudio says this about the videofile:
Audio :
Video :
MPEG-2 Video
4:3 Rate
720 x 576 Größe
480 Bilder
4505 Kbits/Sek.
Dolby AC-3 Audio
Stereo Modus
48.00 kHz
2 Kanal(Kanäle)
I have no problems to import with audio from DVDs i created with VideoStudio so i guess it could be the audio setting of the DVD-HDD recorder?
If so, wasn¡¬t there a AC3 plugin available at Ulead website? I can¡¬t find it anymore. Does VS9 supports AC3 sounds or do i need to get VS10?
Rends
Does VideoStudio 8 support AC-3 Audio?
Michael - yes there was an AC-3 plug-in for V8 - but I haven't seen it on the Ulead website for sometime.
Version 9 comes with 2 channel support for AC-3 (Dolby)
Version 10 includes support for 5:1 Dolby digital
You can find a bit more about both versions here :-
http://www.ulead.co.uk/vs/compare2.htm
Rends
