Hi everyone,
I have been a fan and user of DVDWS for a few years now and have just joined the forum.
I have 2 questions and will post them seperately.
In DVDWS2 full version:
Import a file that has been captured as m2p with vision (not black) from the start to end of clip. (Actually a portion of a program).
Select a desired start point soem time in from start.
Cut title. You see warning message and then an updated first icon. Works fine.
Set up a simple menu with just that chapter point on it.
o to finish to preview. Press play. Menu appears. Double click menu.
Before the clip plays you see a flash of the first fram of the captured clip.
Very annyoing.
Anyone got any ideas?
Flash frame when cut title
Bob Glover
Cut title with m2v
Hi again everyone,
Further to my other post regarding flash frames when cut title.
I tried same thing on n SE version that came with a burner.
I followed same procedure and got a frame of black at head instead of the first frame of vision. I was using m2v file for that.
What also happened was that as soon as I cut the title, the audio(I was using seperate WAV file.) went haywire... out of sync by many seconds. It was as though the begining of the audio track was starting at my vision cut point.
Any help greatly appreciated.
