I have the following problem:
I want to end a film in a shot which first zooms out and the slowly pans to the right and then stops for a couple of seconds. I have used Freeze Frame command to stop the image at the end. It all looks good on computer screen (project file), but when I render to MPEG2 (2 passes) and export to DVD... the zoom and pan play back jerky and the image moves almost like a "wave".
Does anybody know why this happens and how to resolve it?
Thanks,
Maukka
Freeze Frame - problem with zoom
videomartin
I assume, you see there on that frame (same on AVI, i believe) the jumps between Half picture A and half picture B, because there are diferences.
One way to fix that a little ist to use the settings for a still picture for that frame (right click that frame and select Media options, anti flicker)
Best way could be to load that frame into video paint, select frame size and duration and save that as a *.uvp and load afterwards that *.uvp instead of the last frame into the timeline.
