Is there a way to return to the selected button in the menu rather than always returning to the default button for the menu?
All comments are welcome.
Dennis
WS 2.0 Return to the selected button rather than the default
So... If I understand you...
You want to select a chapter/program, and when it's done, you want to go back to the menu, default to the same button selection, and repeat that selection...
In that case, I think you'd need multiple menus that "look alike" but have different default selections. Each button would have its own menu, which is linked at the bottom of its playlist.
That wouldn't be too bad if you don't have too many menus & buttons already.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
dennisbthomas
Sorppa
Re: WS 2.0 Return to the selected button rather than the def
Yes, there is. From the question I gather that you are in a menu, let's call it menu A, you click a button, a clip is played and then you return to menu A, with the default button for menu A selected. You want that the same button that started the clip should be selected instead of the default button. You can accomplish this quite simply. In the procedure below I assume you have made a menu with a button that starts a clip and then returns to the same menu. The procedure is applicapable in other cases too, with some natural modifications.dennisbthomas wrote:Is there a way to return to the selected button in the menu rather than always returning to the default button for the menu?
Procedure:
1) Select the button that starts the clip.
2) Click on "Playlist" in the window for buttons etc to the upper left.
3) In the playlist, the last item will be something like "Main menu". Double click on this item.
4) A window pops up where you can see the menu and its buttons. Click on the button you wish shall be selected on return, then click "OK".
6) The item in the play list will now look something like "Main menu - Button 3".
Done!
As you see, there is no need to duplicate menus.
dennisbthomas
- ram: 2 GB
- sound_card: Intel GMA 950
Try looking at:
Learning Centre Tutorials For DVD Workshop 2
Learning Centre Tutorials DVD Workshop 2 Video Tutorials
http://phpbb.ulead.com.tw/EN/viewtopic. ... enu Pages]
Look for 'Playlists'
