Back to Menu option for Chapters ???
LaSeR
Hello to all.
As I am new to this forums (I recently download VS10+ Trial B4 Buy), I would like to apologise if my problem is already answeared.
I have a clip about an hout lenght.
I want to have a menu for playing center parts of the clip.
If I choose to make chapters I cannot go back to menu after playing one chapter selected in menu.
If I choose to split the clip into smaller parts from main menu creation I can play that certain part of the clip and choose to go back to menu.
Second choise is ok, but it comes with another problem.
Between 2 parts of the original clip there is a part which I want to be played when play entired project is selected from menu.
If I also include that parts on main menu clips, I haven't got the option to hide them from appearing to main menu.
--------------------------Original Cip----------------------------------------
|Menu1||fullplay1||Menu2||fullplay2||Menu3||fullplay3|....................
Is there a solution to this problem?
I don't think VS can do want you want. You need a more sophisticated DVD authoring program, such as Ulead's DVD Workshop.
Jeff
Dentler's Dog Training, LLC
LaSeR
Can I HIDE a Chapter in VS10 ???
I cannot find the way of hiding a chapter from displaying at menus.
That option was in VS9.
Anybody knows something about it?
LaSeR
Thanks For Reply.....But that isn't the problem
Hi Vidoman,
Thanks for replying, but maye I wasn't clearly understood.
Suppose we have a project with 3 clips for main menu.
The 2nd clip has 8 chapters via the add/edit chapters menu.
I want to Hide chapters 3,5,7 from displying in chapter menu of clip2.
In VS9 when you add chapters from add/edit chapters, we had the option to HIDE chapters.
I cannot find that option in VS10+.
Can We????
Can We????
You are correct. I had to go back to VS9 and look at the Add Chapters. There is a Hide button, that allows you to hide specifically selected chapters. This is not found in VS10+. The closest that I was able to find is, after adding the chapters, and going to the Menu Edit, you can right-click on the thumbnails and choosing Hide Object. This does about the same thing.
Now for the kicker, I hid 3 chapters then rearranged the remaining ones. This caused a couple of chapter thumbnails to be stacked. VS warned about this, and asked if I wanted to continue. I choose yes, and proceeded. The hidden chapters are still accessible by clicking a number button for the hidden ones. Then the remaining chapters can be accessed by pressing the thumbnail or by pressing the corresponding number button. This is different then in VS9, but I think for the most part does the same thing. You have to be careful when "stacking" that they are stacked exactly on top of each other, you may be able to select the hidden chapter while trying to select the one shown. I think that this is a flaw with VS10+...
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Authoring a DVD
Authoring a DVD
Actually, the HIDE CHAPTER and HIDE OBJECT are two different things. The HIDE CHAPTER of VS9 will "remove" that chapter during normal playback of the video. The HIDE OBJECT is a menu-specific thing, and if you are hiding a chapter object (like a thumbnail), I believe that chapter will still play during playback.vidoman wrote:You are correct. I had to go back to VS9 and look at the Add Chapters. There is a Hide button, that allows you to hide specifically selected chapters. This is not found in VS10+. The closest that I was able to find is, after adding the chapters, and going to the Menu Edit, you can right-click on the thumbnails and choosing Hide Object. This does about the same thing.
@Steve,
Can the Tutorial Link you provided be updated to include the distinction between HIDE CHAPTER and HIDE OBJECT? Also, the 1/1 in your example of Hiding an object is in the Lower Right.
George
Noted I will update the tutorial when I get the chance. - Steve J
LaSeR
Hide Clip in Main Menu ???
Vidoman....
I cannot find what you have described....
In Main Menu only options available are (Change Thumbnail,Rest Thumbnail and Media Clip Properties) and all that applies to Clip Not Chapters...
sjj1805....
I read it before...I read it again....
There isn't anything regarding this problem.
GeorgeW...
HIDE CHAPTER of VS9 will still play that chapter althought it doesn't appers in Clip's Chapter menu
And again Where is that "HIDE OBJECT" you are describing...
Is there in VS9 & VS10+ or you are using another product????
sjj1805....
GeorgeW...
Re: Hide Clip in Main Menu ???
During normal playback, without hitting the NEXT button on your remote control, are you saying the chapter still plays for youLaSeR wrote: GeorgeW...
The HIDE OBJECT is on the MENU (after you add your chapters for the clip). Rt-Click on a menu object (lile a thumbnail) to see the HIDE OBJECT option (in VS10+).
George
