Trouble trimming last milliseconds off
Mapilowee
Post by Mapilowee »
Hi all,
I have a series of videos with durations ranging from 5:00:01 to 5:00:03. I've been trying to trim the last milliseconds off to 5:00:00 using the video duration tool in VideoStudio 6. Whenever I try to reduce the time, it goes from 5:00:02 and jumps to 4:59:29. The videos are 29.97 fps NTSC MPEGs.
I used to be able to trim down to 5:00:00, but when I patched the program to 6.02, this issue started happening. Is there a way to uninstall the patch w/o reinstalling the program? (I don't know where the program CD is anymore).
Thanks for your help!
DVDDoug
Moderator
Post by DVDDoug »
This is due to the MPEG structure.
The MPEG is encoded as Groups Of Pictures (GOPs) The GOP typically consists of 12 to 15 frames, which works-out to about half a second.
The GOP starts-out with an I-Frame, which is a full image. P-Frames or B-Frames follow, which essentially contain the differences/changes from the I-Frame.
Generally, edits need to start on an I-Frame. You would think that you could throw-away extra P or B frames at the end, but maybe this confuses the encoder/decoder.... I dunno... :?
Maybe you were working with a different file format. :?: Or, you may have just been lucky, with the GOP ending at 5:00:00. (On average, you should get lucky once out of every 15 files. :wink: )
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
