Top of heads chopped off
Hi all , I have no problem using PS4 , everything works fine, however I notice that in many of the slide pictures the a portion of the top of the heads is "chopped off" Yet when working on the picture s in Uleads Explorer or Photo Impact the picture hAS PLENTY OF SPACE ABOVE THE SUBJECT. Its probably some resolution setting I need to change in PS4 in order to hget the full view in the slide show. ? Any suggestions Thanks Rick
Rick Fredrickson from Northern California
htchien
Press the F6 key in DVDPS then you should see a Preference dialog to appear, search for TV Safe Area option and then modify its value. Usually I use 15% for that.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
