I keep getting a "Failed to Burn Disc" [534: -214721691: 0] error when I burn try burning a project to DVD. Does anyone know what this issue points to. Hardware, Software, ?????
Just upgraded from V7 and installed. I can burn DVDs fine with Nero.
thanks
.rick..
Looking for VS10 Error codes or log file.
Are you following the Recommended Procedures in the top sticky post on this Board? That recommends against trying to burn a project directly to disc. Instead, you should first go to Share > Create Video File > DVD and prepare a DVD-compatible mpeg-2. Then close your project, open a new one with an empty timeline, and select Share > Create Disc > DVD, insert your new mpeg-2(s), create menu and burn.
rickr
Ok... Not originally...... Found it after I posted... Even printed the whole thread..
Last night I reconfigured and followed the procedure, using the info for DV-> AVI capture. Created the MPEG2 file., but still get the same message at burn time. It may not like my Memorex USB burner. The MPEG2 burned fine in Nero. So for now I'll create in VS10 and burn in Nero.
.rick..
.rick..
rickr
