Display Artifacts
lances
Display Artifacts
Post by lances »
Good Day!
I have an issue with this application that I can not resolve. Any time that I move an object on the screen, change its position, etc., I have a thin line that appears across the x-axis that is usually colored the same as the object. It will change length depending on how I move the object I am dealing with, and sometimes will go away until I move the object again. This line also appears in any redered video overlays or video files that I produce. Has anybody had this before? Anyone know of a solution? I am using vresino 1.0.1
Thanks in advance for your response!
Lance
htchien
operating_system: Mac
Post by htchien »
What display card do you use??
Have you updated the display driver to the latest??
Have you updated DirectX version to the latest??
This problem seems to be a hardware/driver problem. You might need to contact the card manufacturer for the problem.
Hope this helps.
H.T.
Ted (H.T.)
