I have suddenly encountered three problems with PI 11.
1. All plug in filters have stopped working. Whenever I try to use any filter other than those that came with PI, I get the following message:
"Failed to Load the Specified Plugin"
I tried removing and reinstalling all of them to the folder that was made on this computer for filters, but they still do not work.
I have PI pointed to the correct folder that contains the plugins. And I have the correct .dll files to make them work.
2. When working on an image, some of the popups don't work. For example, I clicked on "Adjust", then on "Color Adjuster", and you can see the window pop up for a microsecond, but then it disappears.
When working on a path object, if I hit the button at the top that is supposed to show or hide tool setting, nothing can be seen.
3. I sucessfully created some new presets and added them to my EP. However, when I go to export this new group, the smp file is is in the file I created to hold this new group, but not the thumbnails, even though I checked the box "All thumbnails of the current group".
I am not really used to PI11, so I am wondering what I may have done to cause all this. Thanks in advance for your help.
PI 11 problems
htchien
It seems your PI install is corrupted. Maybe you need to reinstall it again....
Select Add/Remove Programs in the Control Panel, then select Ulead PhotoImpact->Modify/Remove, you will see the maintainence program of PI to appear. Select Repair and let the maintainence program do its job.
If this does not work, you need to do a remove / install process of PI.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
