Choppy DVD playback on DVD players
schatz98
I made several DVD movies from family DV, that was downloaded in DV format and then edited and then finally recorded on DVD.
I have a newer set top Sony DVD w/ progressive scan and a TV that has progressive scan capabilities.
when I play the DVD, some areas of the video is very choppy and pixilated and sometimes stops playing. I can play that same DVD and play it on an older Sony DVD player that I own and it works just fine.
The DVDs are DVD+R format disks
Some of my other family members have said the same thing about being choppy, etc.
Any thoughts? Is this a video recording format issue, a DVD+-R issue, progressive scan DVD player , etc.
Please help me out
Please help me out
heinz-oz
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
DVD Burning / Playback issues
schatz98
My DV settings are:
AVI(DV) Capture Properties:
NTSC drop frame (29.97 fps)
Microsoft AVI files
24 Bits, 720 x 480, 16:9, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- NTSC, 48.000 kHz, 16 Bit, Stereo
and my settings for when I burn to DVD are:
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
Audio data rate: 256 kbps
Microsoft AVI files
Lower Field First
MPEG files
Lower Field First
(DVD-NTSC), 16:9
heinz-oz
Since some play fine and others don't, it sounds like DVD player compatibility issues with the +R discs. Follow Steve's link and check if that is the case.
This link will take you right to it.
Jeff
Dentler's Dog Training, LLC
schatz98
maddrummer3301
