I have been using Photoimpact 8 since early 2003, the "Have encountered a problem and must close" has turned up two or three times in the past few years. I have been able to fix the problem up until now. This time I have ran out of ideas and decided to reinstall the software. My problem is that I can't find the paper CD wallet with the nine digit serial code which is needed for a reinstall. I used the add/remove 'repair' option but to no avail. How can I reinstall without the code.
Sean Patrick
photoimpact 8 problem
- ram: 2 GB
- sound_card: Intel GMA 950
Please click here -->
so that we can then view your system specifications.
If you had done so before then I would know if you are running windows XP in which case I could then advise you to try using 'System Restore' to return your computer to a point in time before you uninstalled PhotoImpact so that you could retrieve your serial number.
