I recently made a DVD using Video Studio 10 without difficulty. I am using the trial version.
When I tried to burn part two of my video [a separate project] the preview pane worked fine when I played the project in 'Edit' mode.
When I tried to burn it using New project>share>Create Video file the preview pane was jumpy and even paused [froze momentarily] when I played it.
I've also struck the same problem when trying to 'Create Disc' straight from the menu.
The final DVD copy was similar - jumpy and pausing at times.
I'm not aware of any changes to the preferences that I may have made since I successfully completed the first DVD. Any ideas?
Playback errors when creating disc
Are your following the Recommended Procedure?
Some people can burn a disc with no problems (your first one) by following the user's manual, while others can't (your second). The Recommended Procedure was designed to work around seeminly inherent problems while burning.
Jeff
Dentler's Dog Training, LLC
