The Auto Music does not seem to been functioning with my VideoStudio 8.00.0000 software. Clicked the Audio tab in the step panel and then clicked the Auto Music tab. Library: box is blank, Music: box is blank,
Duration and Variation; boxes are blank, " Play selected music, Add to Timeline, Smartsound Quicktracks: all are not active.
Does anyone know what I am doing incorrectly or is this a problem with the software?
Auto Music function not working
It sounds as though you have not installed correctly, as though you have missed the Quick Track install process.
From what I remember there is a big delay during installation prior to installing the quick tracks.
You may have assumed installation to be complete.
Browse the install folder for a Smart Sound folder.
Run the Full Spectrum 22k.exe
And Quicktracks.exe
Hope this works
And Quicktracks.exe
Hope this works
I had a similar problem to you - first I ran the "full Spectrum 22.exe" file on the CD - this installed the music files on my hard drive but they were still inaccessible from UVS8. I then tried to run the "quicktracks.exe" file on the CD but got the error message saying that it required the /s parameter so I had to resort to running the file from the 'Start' >> 'Run' box using the command "R:\SmartSound\Quicktracks /s:" where 'R' is my CD-rom drive (note the space before the /s) this ran - (note it appears nothing is happening but watch CD drive light) installation finished started UVS8 and HOORAY all the smartsound works.
jkennard
Got it working - Thanks to Trevor and Brian for your suggestions.
In addition, I had to initiate Full Sprectrum 22K.exe before the Auto Music feature was fully fundtional.
Birondino
Yes thanks. I was missing the full spectrum audio music as well. Thanks Trevor and Brian!
naginat
jkennard, what did you do exactly to initiate "Full Spectrum 22K.exe"? I am having the same problem with Auto Music and following the steps detailed by BrianCee did not help resolve it. I have the QuickTracks plugin installed (shows up in windows 2000 Add/Remove programs list). I also have the music files installed in the "doc settings/all users/app data/Smart sounds" folder. I don't know what else needs to be done. Is there a specific order in which the program patch, QuickTracks plugin & Full Spectrum need to be installed? Plz help!
cbirais
Same problem but now all is OK
1° check if you have the latest quicktime. you can download it at apple.com. You can't download it alone, it is in a pack with Itunes.
2°In start/control panel/add remove, uninstall smartsounds quicktracks and ulead.
3° before installing again ulead go to smartsound web site http://www.smartsound.com/support/answers/index.php then select "quicktracks for ulead videostudio8" next page select line Nb 3 "smartsound does not work with ulead......"
Note when you install ulead you install quicktracks.
For me after reinstalling UVS, Fullspectum was not correct, some music were missing.
I made a second desinstallation with "suppress plus", reinstall uvs, reinstall fullspectrum and overwrite all the 26 songs and now all is perfect
Good luck
Claude
Good luck
Claude
