Hi all,
Is anyone there who can tell me how to make a simple audio loop..
I've got, for example, 2 minutes of video and a simple audio file, 30 seconds, and I'd like the music cover all the 2 minutes of video with a simple audio/music loop...
Can you help me.. THANKS
audio loop
The simplest and quickest way with the software you already have is to just place multiple copies of the sound clip along the sound track in the timeline of VideoStudio until it reaches the required duration.
A perhaps more proffessional way might be to take your sound clip into an external sound editing programme (like Audacity) where you would basically do the same thing but then you could manipulate the beginning and end of each segment to form a seamless join.
BuZZarD
I use a program called octamed soundstudio (based on octamed from the Amiga (ahhhh nostalgia...)) which is a sampler/sequencer and costs about £12 for the program and up to £20 for the DVD version with a ton of samples etc.
I then select a sample, loop it, then record it as a wav for the duration I need.
It's great for assembling sound and music scores to go with my videos and has full midi support if you require it.
taleequale
