No Right audio
Piet
No Right audio
Post by Piet »
On my last two captures the rt audio is missing on all clips. Audio wise and on the VU meter.
The camcorder is recording Rt + Lt channels and both are OK on replay at the camera.
I havn't noted this before but is the VU meter supposed to be activated when playing a clip versus playing the project where it does.
Thanks in anticipation..........
Piet
Post by Piet »
By doing a few test recordings have got the rt audio to capture. Not sure as to the actual cause but suspect the camcorder, even though there was rt audio on the earphone output.
On reading the manual noted that audio metering is not operational on clip, project only.
If all else fails read the manual!
TDK1044
Post by TDK1044 »
If you were really stuck, there is a feature in VS10 that allows you to duplicate a specified audio channel so that your resulting DVD audio will play out of both speakers on your TV.
Terry
