videostudio 9 output disk format
morrish26
Post by morrish26 »
I have video studio 9 but cannot burn to disk as it tells me i need a CDRW/VCD disk to burn images. My video has images, video and audio on. My DVDRW recognised i have a DVD in the drive but thats as far as i get. On the create disk screen in video studio the output disk format drop down only has VCD in it, does this have to be changed to DVD and if so how do i do it?
Please help as i am banging my head with frustration.
I have checked the DVDRW and am confident there are no problems there.
They might be the same physical shape and size but a DVD holds 6 times more information than a CD.
CD = 650/700MB
DVD = 4.3 GB
Please view: Authoring a DVD
heinz-oz
Post by heinz-oz »
In order to give any meaningful help we need a lot more info. Have a read of this and fill in your system spec's in your profile. http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Have you been able to write DVDs before? Maybe you only have what is known as a DVD Combo writer. This device can read DVD but only write CD.
Post by BrianCee »
Could you tell us what version of VideoStudio you have Tracey - I know you said 9 but is it by any chance a version 9 SE - the SE is quite important as it tells us that you have a Special (Simplified) Edition which may not be able to burn DVDs - was your copy of VideoStudio free with something you purchased.
Unless it specifically says Version 9 SE DVD it is very likely that it is not able to burn DVDs and that may be the root cause of your problem - the easiest solution is to upgrade to a full edition but you could also create an mpeg2 file in the version you have and use another programme (Roxio, Nero etc. etc. ) to burn a DVD.
morrish26
Post by morrish26 »
BrianCee wrote:Could you tell us what version of VideoStudio you have Tracey - I know you said 9 but is it by any chance a version 9 SE - the SE is quite important as it tells us that you have a Special (Simplified) Edition which may not be able to burn DVDs - was your copy of VideoStudio free with something you purchased.
Hi Brian, thanks for your reply. My videostudio 9 came as a set with the PYRO BasicDV hardware that i had to install to allow my video camera to plug in to the computer. As for it being an SE version i am not sure it doesn't say it on any packages i have bu the SE bit rings a bell when i was loading the progame on my computer.
Post by BrianCee »
If it came as part of a package of any type then then we can be 99.9% sure you have an 'SE' version - - just to be sure - open VideoStudio and up in the top right corner of your screen you will see a question mark, a minus sign and an X
Click on the question mark and from the pop-out which appears choose "About Ulead VideoStudio" - an information panel will appear with the version number under the picture - if it only says "Version 9.00 SE" (or similar) then it is almost certain you can not burn a DVD with it
To burn a DVD with an SE version it must specifically say "Version 9.0 SE DVD" - if DVD is not included in the SE version symbol I'm afraid your only options are those I described in my previous post.
morrish26
Post by morrish26 »
BrianCee wrote:If it came as part of a package of any type then then we can be 99.9% sure you have an 'SE' version - - just to be sure - open VideoStudio and up in the top right corner of your screen you will see a question mark, a minus sign and an X
Hi Brian,
The version i have is version 9.00 SE DVD as it says in the 'About Ulead Videostudio'. Where do i go from here? I am really stuck, should i just bite the bullet and call in a computer expert as i seem to have tried everything and my knowledge only goes so far.
morrish26
Post by morrish26 »
Hi Brian,
I have read the authoring a DVD section but it still doesn't help me when i try and burn a DVD. I keep getting the message-
'You need a CDR/RW to burn a VCD/SVCD disk image file. Please change the disk and try again.'
This brings me back to my original question should it only say in the 'Output disk format' drop down list VCD or should it say DVD?!!
Can anyone help?
morrish26
Post by morrish26 »
sjj1805 wrote:Image
In this list on my screen i only have VCD in it, what does this mean?
It sounds as though you have VideoStudio 9 SE
and not VideoStudio 9 SE DVD.
Please re-check the "about Ulead VideoStudio" box again.
I know this might sound daft but you do have a DVD writer and not just a CD writer don't you?
Please click here
morrish26
Post by morrish26 »
sjj1805 wrote:It sounds as though you have VideoStudio 9 SE
Please click here
It definitely says Videostudio 9 SE DVD and i have a LG 16 x super Multi DVD/CD Rewriter which is brand new.
Anyway since last talking to you i have upgraded to Videostudio 10 which seem a better program all round. I have now tried to burn my saved clpis on to DVD but alas i now cannot open them in the create a disk screen, any ideas?
I think we need to start with all the basic stuff.
Firstly may I ask you once again
Please click here --> Image
Once you have completed that step, please detail the following.
What was the original source of your video clips. Were they from your camcorder, ripped from a DVD, downloaded off the internet or some other source?
How did they get into your computer, e.g. via an IEEE1394 (firewire) cable, TV card or some other means.
What did you do with those source files - e.g. made edits to them.
Did you then create DVD compliant MPEG2 files and if so what were the settings e.g. PAL DVD / NTSC DVD. Bit rates, dimensions e.g. 720x576
Audio format. The more you can tell us the better the chances are tht we can help.
Have you viewed the following
From Camcorder to DVD with VideoStudio
morrish26
Post by morrish26 »
sjj1805 wrote:I think we need to start with all the basic stuff.
My original source was from a camcorder and was transferred on to the computer by DV connection and firewire. I then edited the files and put audio to them.
I dont know what a MPEG2 file is or how to create one i'm sorry. I just saved my completed files to hardrive.
