Smartsound Software files
- Screwball
- processor: Quad 3.2
- ram: 8gb
- sound_card: soundblaster platinum
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: HP2010i x2
- Corel programs: Pro X6
When I installed UVS9 it included 'Smartsound Software' - Looking through the files and Library, it includes 26 recorded tracks that may be worth looking at, but how does one access them, I can't find a way?
Nothings Easy!
When you have VideoStudio open click on the 'Audio' tab at the top of your screen. Now look to the top left corner of your screen - immediately under the 'File/Edit/Clip/Tools menus is a box with your project name - immediately under that are two tabs - one labelled "Music & Voice" - which is selected by default - and the other tab is labelled "Auto Music" - click on the Auto Music and you will have acces to all the controls you need to access /modify/ use the 'Smartsound' tracks.
The first time you use it it may take a second or two to initialise and then a couple more to load the tracks - but after that it is usually instantaneous.
