I am new to Ulead DVD MovieFactory 2.5 SE but have been using Ulead VideoStudio with no problems. When I bought my PC the software came along with the package.
My Video card is WINFAST DV2000.. Using the Winfast software (Winfast PVR) I am able to clearly get TV and video reception so I know I can get a clear picture to my PC.
I am unable to get a clear picture when I use Ulead DVD MovieFactory 2.5 SE. It is black & white, distorted & fuzzy. And the only time I see that is I select "Video Composite" in the Input Source.
In Capture Settings I have tried all the different options. One thing I can't change in the Video Capture Property Settings, in Video Input, is the TV System. It won't accept any change to PAL or SECAM, it stays on NTSC. But in the Preferences (F6) the TV system is set to PAL/SECAM. Australia is PAL.
The cable I'm using is an S-Video coming out of my PC and the other end that plugs into my VHS player is the White, Yellow & Red RCA connections. It came with the video card and I use the same cable to get the clear reception I mentioned above.
Can someone please help?
Thank you
Aussie.
Fuzzy/no picture.. new user
htchien
Have you:
1. Applied all update packs for DVD MovieFactory??
Ulead DVD MovieFactory - Support Info:
http://www.ulead.com/tech/dmf/dmf.htm
2. Updated the driver of your capture card??
LeadTek Research Inc. - Tech Support - Driver Download - WinFast TV2000/DV2000:
http://www.leadtek.com.tw/eng/support/d ... t%20DV2000
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
