hi,
wonder if someone may advise me on that issue.
my business is to uniform size id photo with the size of the person face to 32 mm.
manually i shot the person and make a unform template and paste a copy of that face in it. Then i size the face to 32 mm and merge and print.
is it possible to do it by task menu?
thnks
mark
looking for pi guru advise on task menu
heinz-oz
Not sure about your problem. The size of a print is given by the pixel dimensions and print resolution. You could use the Task Menu as long as your images have the correct aspect ratio. All you would have to do is to resize the image. It is not possible to use a task if your images are of different sizes or need cropping.
